Compatibility issue? Blurry textures, bad lightning, low shadows, tessellation
jboing
I got a ASUS CM 6870 that i upgraded with some RAM, 650W power supply and a Gigabyte gtx660 OC, everything runs smooth on ultra high settings, but there are some issues with lightning, tessellation, shadows, sometimes textures pops and random bad quality textures...the card doest seem to use its full potential... I tried bios updates, default settings, different drivers, voltages, clean windows install... is it a motherboard compatibility issue ?
https://www.asus.com/Desktops/CM6870/#specifications
Are these the only video cards compatible ? or do i simply just have to wait for an update ? Please help
Asus CM6870
650 W Power supply
P8 H77 M Pro motherboard (revision something, 0.x0)
i7 3770 3,4 GHz CPU
Gigabyte GTX660 OC
2x4 stock + 2x8 RAM
...the motherboard is not exactly the same as this http://www.asus.com/Motherboards/P8H77M_PRO/#overview ,
when tried to update bios, security verification failed... i have seen there are other ways, but if it flashes, will it work ?
[/URL][/img]
[/URL][/img]
