Compatibility Issue, need insight
Reanimation
51
Ok, so here is what I have just received in the mail...
AMD 955BE
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674&cm_re=amd_955-_-19-103-674-_-Product
And
Asus M4A79XTD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402&cm_re=asus_790x-_-13-131-402-_-Product
Now, the problem is, the cooler I have is this...
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003&cm_re=xigamatec-_-35-233-003-_-Product
Which I thought said was AM3 compatible, but now I see it does not say that at all. Long story short, will this cooler work with the CPU Mobo, or do I need something else?
