compatibility issue with graphics card
shreyasp1492
22
1.Is there any compatibility issue of ASUS P8B75-V motherboard with asus ati radeon hd 7770? my vendor said it displays blue screen after say around 2-3 hrs.
2.Hows the compatibility of the same card with Gigabyte GA-B75M-D3H Motherboard???
3.How to check whether a particular combination will run without any problem??
i'm using i5-3450 processor with 8gb(2*4) 1600 mhz ram and 500w power supply.
pls rply asap! thanx!
make sure your motherboard running the newest bios file to rule out a bios bug. when you run a gpu for a few hours make sure you use a 3 party tool called msi afterburner...set the fans to run at 100 percent at 50-60c.
a lot of times to keep the noise down the gpu vendors keep the fan from maxing out. this can cause durning long game play to make the gpu over heat.
ok thanx rolli59.
bt pls guide me how to tackle with the vendor abt dis. he keeps on saying "no, i've checked with the config. it gave me prbms everytime blah blah.." which ques should i ask him abt the same.
will keep in mind smorizio... cheers man!!
i already have msi afterburner it gave me temp around 75-76c with my existing sparkle nvidia geforce gtx 550ti and intel dh67bl mb
the main prob is its giving me flickering problems. dats y i ask vendor to change mb and graphics card!
ya.. both the boards are compatible with the card right? there should not be any compatibility issue between them right?
