Hello,
I am thinking of adding a Kingston 1GB RAM memory, part number KTH-D530/1G, to my Dell Dimension 1100 PC. More information about this memory can be found here:
http://
From the manual of my PC, the motherboard does accept 1-GB non-ECC 400-MHz DDR SDRAM and in theory, the Kingston KTH-D530/1G memory should be compatible with my Dell PC.
However, from the www.computermemorysolutions.com website, Dell Dimension 1100 is not mentioned as a PC with which the KTH-D530/1G memory is compatible.
Do you think that the KTH-D5301G memory will still be compatible with my PC even though Dell Dimension 1100 is not among the PCs in the Compatibility list of the Kingston KTH-D530/1G memory?
Thanks for reading
Kindest Regards
Jean Luc
http://
Thanks for reading
Kindest Regards
Jean Luc
