compatibility issues with GIGABYTE 990FXA-UD3 motherboard and EVGA - GeForce GTX TITAN X 12GB GDDR5 video card
rEignz
Commendable
May 26, 2016
7
hello guys!
I am planning to buy an EVGA - GeForce GTX TITAN X 12GB GDDR5 video card to replace my current one (AMD Radeon HD 7800 Series) which I am currently having problems. I would like to ask though if the EVGA - GeForce GTX TITAN X 12GB GDDR5 is compatible with my current motherboard (GIGABYTE 990FXA-UD3) before buying. If it doesn't then what would be a good replacement?
Sorry for the ignorance guys, but what do you mean by the 1070?[/quotemsg]
GTX 1080(out tomorrow or something) and GTX 1070(out on the 17th of june) = the next generation of GPUs from Nvidia.
The flagship 1080 is more powerfull that the TItan X.
http://www.tomshardware.co.uk/nvidia-geforce-gtx-1080-pascal,review-33557-6.html
+1
Or, if you must have the best, get the 1080. it beats the titan x by a fair amount.
You will be bottlenecjed by your CPU regardless, though.
Gtx 1070 or gtx 1080 it's the newest nvidia gpu line that comes out tomorrow. The 1080 is faster than the Titan u want, and cheaper the 1070 is faster than your CPU is capable of pushing it. No idea what cpu u have but it's AMD so it can't push a Titan/1080 to their limits
+1
