Compatibility issues with motherboard
joshsadler98
16
Hi guys I was wondering if you could help me in regards to piecing some hardware together to make a build. Basically I have two parts below being the motherboard and case. I was wondering if you'd be able to tell me if they would work together and that the motherboard will support an i3 2120! Finally, if the motherboard will hold a PCI-E WLAN Card.
MB -
ASUS / RM MINI ITX SOCKET 1155 DDR3 MOTHERBOARD - P8H61-I LX R2.0/RM/SI
Case - https://www.amazon.co.uk/Kolink-Satellite-PC-Casing-Black/dp/B017E64OQS/ref=pd_sbs_147_4?_encoding=UTF8&pd_rd_i=B017E64OQS&pd_rd_r=99424d3c-e7eb-11e8-af2c-cb08b2b3dee4&pd_rd_w=SArHd&pd_rd_wg=hcjAf&pf_rd_i=desktop-dp-sims&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=18edf98b-139a-41ee-bb40-d725dd59d1d3&pf_rd_r=SPBQHJ802DE6ZDF3MA4G&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&refRID=SPBQHJ802DE6ZDF3MA4G&th=1
Thank you so much in advance.
