compatibility note issue :S
jatin_25
51
Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard has an onboard USB 3.0 header, but the Cooler Master HAF 912 ATX Mid Tower Case does not have front panel USB 3.0 ports...
- is this a major issue ? should i change the cabinet or is it ok to with cooler master HAF12 ?
If you want front USB3.0, try another case, for example, NZXT H440. If you dont want to change the case, just use the USB3.0 ports at the I/O
We offer a front USB 3.0 5.25" Panel (Part Number: 621024410-GP) specifically for your HAF 912 at the following link:
http://www.cmstore-usa.com/haf-912-usb-3-0-5-25-bracket-oem-package/
Please let me know for further questions.
Regards,
Felinni M.
CMUSA Support
