[SOLVED] Compatibility of gtx 1660 super with Gigabyte GA-970A-UD3P ATX AM3+ , please help
Sai Prathik
213
Hello guys,
My pc build is (5year old build)
Fx 8320
Ddr3 16 gb ram
R9 290 sapphire
Seasonics 750 watts psu
Gigabyte GA-970A-UD3P ATX AM3+ Motherboard
Actually my gpu r9 290 has three fans and one fan stopped working
So iam thinking of replacing it
Actually i dont have money to build a new pc.
So can i use gtx 1660 super with my current build without any bottlenecks?
Or do you think i should upgrade cpu mobo and gpu and ram
Thanks for your support
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($117.68 @ Amazon)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard ($79.97 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory ($67.98 @ Amazon)
Custom: R9 290 Tri fan replacement eBay($28.00)
Total: $293.63
vs
EVGA GeForce GTX 1660 SUPER SC $230
Adding the 1660 super would give you higher Max FPS but would do nothing for the lows and spikes, that is on your CPU.
A 2600 would add 20+fps to the Low with much less spiking and a 3600 would add close to 30+ FPS for something like $77 more. You could coast by a few months and grab a GPU from there...
Total: $293.63
vs
Selling the FX chip/MB and RAM would give you a return of around $100
Reactions: Sai Prathik
Total: $293.63
vs
Thank you so much sir. I really appreciate ur help. I m going select the first option
