Hey guys, I'm completely remodeling my computer and just wanted to be triple sure that everything I am fixing to buy will be compatible with what I have. From the hardware, to the sizes and dimensions of my products. Here is all that I have and am buying that will be put together.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU:http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Heat sink: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121770
And the PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182278
I also have 2 sticks of ram, and only 1 HDD and an SSD. Thanks for the help guys.
