Compatibility? With monitor stand
Hussein9704
Commendable
Jan 3, 2017
32
Hey im just asking If the Mount-It! Dual Monitor Mount Desk Stand for LCD LED Computer
Is compatible With the Asus rog swift pg258q and the Acer K242HQL
Like, With the size, Weight and right screws
Because In the manual for the Asus screen it says "use only UL certified monitor stand"
So is it compatible with as I said weight, screws, right holes for fitting it, and size
And is it UL certified?
this stand could support up to 27 inch screeen and it have vase monut for the 75 100 mm set up so the asus will fit on with the acer took me 1 min to find all details on google .
What about the ul certification?
1. So why does it then say in the manual that the stand has to have that certification
2. Btw does the stand have the right screws ( m4 x 10mm) ?
3. Is also says that the stand minimum weight capacity should be 22,7 kg so is that stand enough for both of the monitors with the weight?
"Use only the UL Listed Wall Mount Bracket with minimum weight/load 22.7kg (Screw size: M4 x 10 mm)"
That is what it says in the manual and the monitor mount can hold up to 19 kg but it says that it should be at least 22,7 kg so im still worried.
Does the monitor stand use the correct? screws (m4 x 10mm) ?
last quiestion what about in the manual for the asus monitor it says that you should use a monitor stand cappable of atleast 22.7 kg weight or something like that
but the one i want is cappable of 19 kg
am i then safe
btw is the monitor mount good or bad?
thx dude
then i will buy that one i linked you and use it with the asus and acer
i was just worried about the 22kg because i didnt want a expensive 240 hz monitor to fall down and break.
but is the desk mount i linked you good or is it bad
why would it not work?
240hz for gaming
60 hz for everything else
wont that work?
Also If im only gonna game on the 240 hz
BTW my gpu is a gtx 1060
Can i Then connect the crappy 60 hz to motherboard?
oh you mean integreted graphics?
