Compatible Case Fan?
Mystic35
13
So I recently bought a Corsair Carbide 500r and it comes with a 200mm fan, but I dont like the color of it and I plan to buy a new one. So I came across some 2500mm and 230mm case fans, but Im not sure if it will fit the 500r. The fans are BitFenix Spectre Pro 156.3 CFM 230mm Fan and REXFLO Silent Blue LED 250mm Bearing Case Fan with 4 Pin Connector. Both Fans are from Amazon and I need to know if both of them would fit my case?
