Compatible Case? for cpu cooler?
Mystic35
13
planning to get this case AZZA Mid Tower Computer Case CSAZ-301 so I checked the websitebut it did not adress any information about compatibilty for tall cpu coolers that can space out for 165mm heatsinks and with the large 250mm fan attached to the side panel. So Im asking if this case supports tall cpu coolers.
The 250mm fan attached is 25 mm in thickness if not probably a little more so I'd say your best route would be to go for an AIO in that chassis but if you'd like to go for air cooling,
^Thermalright True 120 - Dimensions: 63.4 x 132 x 160.5mm (LxWxH)
^Coolermaster Hyper 212x - Heat Sink Dimensions 116 x 51 x 158 mm
^Coolermaster V6 - Dimension 131 x 120 x 165 mm
^Enermax ETS-T40-TB - Overall Dimension 139(L) x 93(W) x...
^Enermax ETS-T40-TB - Overall Dimension 139(L) x 93(W) x 160(H)mm
* You're fine with 165mm of cooler height regardless. Might need t get rid of the side 250mm fan anyway as it will add more wires to manage while also adding some noise to the system overall.
