Compatible closed-loop water cooling solution
I've been reading all these posts about the dangers and maintenance required for WC, so I've decided to go for a good air cooler out of the fear.
Here's the link for a thread if you wanna help..thread link
Thanks for the help btw.
There are many other options better than the h100i and that website is not the most reliable.
There is not danger of watercooling and you have to do zero maintenance as aio's are not the same as watercooling. the leak chance is so low that I would be afraid of any other part of my pc failing first. With Actual watercooling, leaks don't happen unless you do something silly.
Reactions: Anonymous Penguin
