Question compatible parts for gaming pc build
Jul 16, 2019
21
Hi, thank you
I am building a gaming pc, and i want something around $3,000 to $3,500.
this current build cost is around $3,500
Please check the parts and tell me if they arent compatible and suggest me which part to change or if better parts available around same price
Corsair Graphite 780T Windowed Full-Tower E-ATX Case - Black $259.00
Noctua 140mm NF-P14S Redux Edition 1200RPM PWM Fan $24.00 x 2 = $48
Intel Core i7 9700K Octa Core LGA 1151 3.60GHz Unlocked CPU Processor $589.00
Gigabyte Z390 AORUS ULTRA LGA 1151 ATX Motherboard $395.00
Corsair Vengeance LPX 32GB (2x 16GB) DDR4 3200MHz Memory $299.00
Seagate ST4000DM004 4TB BarraCuda 3.5" SATA3 Desktop Hard Drive $158.00
Corsair RM850x 850W 80 Plus V2 Gold Fully Modular ATX Power Supply $209.00
MSI GeForce RTX 2070 GAMING Z 8GB Video Card $799.00
Microsoft Windows 10 Home with Creators Update 32/64-bit USB Drive $165.00
Noctua NH-D15 Multi-Socket PWM CPU Cooler $125.00
Samsung 860 Evo 1TB 2.5" SATA III 6GB/s V-NAND SSD MZ-76E1T0BW $208.00
Dell External Trayload USB 8x DVD+/-RW Optical Drive - Black $51.98
Creative Sound Blaster Audigy Rx 7.1 Ch PCI-E Sound Card $109.95
ASUS PCE-AC55BT Wireless AC1200 Dual-Band PCI-E Adapter with Bluetooth $68.00
total $3,483.93
_
rtx 2080 above is fine or should i get ?
Gigabyte GeForce RTX 2080 Gaming OC 8GB Video Card $1,099.00
if we change graphic card total $3,783.93
____
just to mention that i only am buying 2x 140mm top cooler however the case i think is more space to put 2 more 120mm cooler in bottom, correct me on this, should i get more bottom cooler if the case has space!
i do need a dvd room
i do need a sound card but not an expensive one, not sure how the motherboard sound is though
i do need wireless and blutooth and card reader too
thank you for reviewing and suggesting
James9002uk
Commendable
May 30, 2017
33
You can probably get these cheaper...
What games do you want to play?
Why the sound card? - could you not wait and test the motherboard sound card?
- Also on that note if the motherboard is this one, it has an integrated Bluetooth module...
Jul 16, 2019
21
yeah i can wait and test the motherboard sound card, im a musician too so i thought maybe i need a sound card, actually i play all types of game since i am a streamer, i already do have another computer which i used to stream and play game at the same time, but i want another gaming pc so i can use my old computer just for streaming
This should be better for the same budget...
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i9-9900K 3.6 GHz 8-Core Processor | $765.00 @ PLE Computers
CPU Cooler | CRYORIG R1 Ultimate 76 CFM CPU Cooler | $99.00 @ PCCaseGear
Motherboard | Gigabyte Z390 AORUS MASTER ATX LGA1151 Motherboard | $438.00 @ Centre Com
Memory | G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory | $259.00 @ Shopping Express
Storage | Crucial P1 500 GB M.2-2280 NVME Solid State Drive | $89.00 @ PC Byte
Storage | Seagate Constellation ES 3 TB 3.5" 7200RPM Internal Hard Drive | $94.59 @ Amazon Australia
Video Card | Gigabyte GeForce RTX 2080 SUPER 8 GB GAMING OC Video Card | $1247.00 @ Skycomp Technology
Case | Fractal Design Define S ATX Mid Tower Case | $129.00 @ Austin Computers
Power Supply | Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply | $170.00 @ Shopping Express
Operating System | Microsoft Windows 10 Home OEM 64-bit | $149.00 @ PC Byte
Sound Card | Creative Labs Sound Blaster Audigy Rx 24-bit 192 kHz Sound Card | $103.94 @ Amazon Australia
| Prices include shipping, taxes, rebates, and discounts |
| Total | $3543.53
| Generated by PCPartPicker 2019-08-21 21:31 AEST+1000 |
Jun 29, 2019
32
I'm not really good a this yet but I see a few mistakes with this build here: The Noctua Fans are overpriced because of their brand, you could get some be quiet! fans, which will probably be priced the same but as the name suggests they are really quiet. Who the heck even buys Windows nowadays. That's right there 165$ wasted. The memory costs a bit too much even if it has 3200MHz and CL15 timings which I don't know haven't checked. You can probably get 32 GB for about 200$ with the same specs from Ballistix for example. The motherboard. Christ that motherboard costs a lot, same price as RX 5700 I think. AORUS always have overpriced for their name. You can find a motherboard with the same chipset and that has both a sound card and Bluetooth module. For example Asus ROG STRIX Z390-E costs 200$ cheaper https://www.asus.com/Motherboards/ROG-STRIX-Z390-E-GAMING/ . The SSD has a normal price, have seen worse. The CPU fan is too much too since Noctua yeah. The RTX 2080 idk why but last I checked that's the price for the Ti version so either the prices have gone up or you meant to write 2080Ti. Last thing: are you sure with the case, because the pricing again is a bit astronomical. You could get a Razer or Corsair or even Fractal Design. Now that I'm checking the prices I see that all of them cost a lot, Corsair also likes to raise the prices because of their name and I can't say that the case doesn't look nice, I'm just saying you should look for ways to save some money and buy yourself a nice 30" 4K monitor with the saving
P.S.: Would like to know why do you need a 4TB HDD and check some other Power Supplies because 200$ for 850W is a lot
