Compatible parts?
mrwil
132
are all this pieces compatible?
optical Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 18.99$
HDD: HITACHI HDS721050CLA362 (0F10381) 500GB 7200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145299 $79.99
Wireless adapter: BELKIN F5D8055 Wireless N+ Adapter (Black) IEEE
http://www.newegg.com/Product/Product.aspx?Item=N82E16833314040 42$
VIDEO CARD: SAPPHIRE 100328L Radeon HD 6770 1GB GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102940 110$
PSU: Antec BP550 Plus 550W Continuous Power ATX12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016 70$
RAM: Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558 $39.99
MOBO: ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271 $121.99
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 225$
CPU cooler:COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 45$
Case:COOLER MASTER Elite 430 RC-430-KWN1 Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227 50$
Arlen10
402
21
That all looks fine. The only thing I would be worried about is that cooler. It's about 6 1/2 inches tall and that case is a mid tower. Might want to look at the dimensions.
Nice build, good luck.
Could also keep an eye out for case sales. I know for sure that Antec 300 (or illusion) will fit the cooler just fine.
Illusion was on sale for under $50 just last week.
However comments on newegg page list that the case fits Hyper 212+ which is the same size as the EVO, so I think you are fine either way.
And if you have the money, seriously consider a Radeon 6870. I think I just saw one on sale for like $140 and if you can get it that low it's a great deal.
Similar threads
