Compatible parts?
das poof
4
Hey,
I am just about to order my first build and i was wondering if these specs are compatible. Any advice is welcome too.
GIGABYTE GA-990XA-UD3 AM3+
Rosewill BLACKHAWK Gaming ATX Mid
ASUS 24X DVD Burner
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16
CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB
Thanks
Get the Samsung Spinpoint F3 instead it has better performance than the WD. It's only $60. I don't know the price difference between the 965 and 955 but you should be fine dropping to a 955 since black edition CPU are easy to overclock. The multiplier is unlocked. Good quality power supply. The rest looks good, you're good to go!
Looks to be that way. With that GTX 580, you might have to remove the removable HD cage to make it fit since it is a large card (my GTX 570 is pretty long)
Otherwise good build. Waiting for Bulldozer I see?
