Hello,
Right then, this is my first post on Toms Hardware and also my first PC build. I do work in IT but as this is my first build - be nice!
From the specs below of the GPU you will see that this PC is not being built primarily as a gaming machine. Most of its life at the moment is be to used as a test environment for virtual machines and perhaps the odd game. My major concern is where or not all of the components are compatible, I have looked at each of the products at least several times and cannot see why there would be any issues - but as I have previously stated this is my first build so I don't want to assume anything!
If there is someone out there who wouldn't mind spending a few minutes looking over the components below and confirm from their own expertise and knowledge that this system will work without having to cut the case to fit the PSU or having to use a hammer (joke!).
Coolermaster Elite 340
OCZ 700W ModXStream Pro PSU
Asus Rampage II Gene Intel X58
Intel Core i7-920
Asus ATI Radeon HD 4650 512MB PCI-E
OCZ 12GB PC3-10666 DDR3 Platinum Low-Voltage Triple Channel (6x2GB)
Case Fans -- 2x Xilence Black 120mm Case Fan
CPU Heatsink & Fan -- Scythe Shuriken Quiet Low Profile Socket 1366
Many Thanks in advanced for any suggestions,
Joel
Intel Core i7-920
Joel
