S sworga Distinguished Aug 7, 2014 78 0 18,630 Aug 9, 2014 #1 i currently have HP Pavilion Slimline s5110uk PC. i would like to upgrade my current PSU (220w) to 400w+ . can you guys suggest some PSU's please? and i'm wondering if series s5000's of slimline product has similar PSU dimensions and connectors?
Solution Dark Lord of Tech Aug 9, 2014 It's a TFX , THEY USUALLY have them up to 350w. That Seasonic is a top quality TFX.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Aug 9, 2014 #2 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%20600014004&IsNodeId=1&name=TFX12V Upvote 0 Downvote
S sworga Distinguished Aug 7, 2014 78 0 18,630 Aug 9, 2014 #3 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%20600014004&IsNodeId=1&name=TFX12V no item's found it say's and i tried searching for similar items but all of them are out of stock :/ Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Aug 9, 2014 #4 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151114 Does your supply look like this one. Upvote 0 Downvote
S sworga Distinguished Aug 7, 2014 78 0 18,630 Aug 9, 2014 #5 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151114 Does your supply look like this one. yes Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Aug 9, 2014 Solution #6 It's a TFX , THEY USUALLY have them up to 350w. That Seasonic is a top quality TFX. Upvote 0 Downvote Solution
S sworga Distinguished Aug 7, 2014 78 0 18,630 Aug 9, 2014 #7 It's a TFX , THEY USUALLY have them up to 350w. That Seasonic is a top quality TFX. okay, thank you very much Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Aug 9, 2014 #8 Your welcome. Upvote 0 Downvote
