[SOLVED] Compatible Water Loop Parts
Sep 4, 2019
6
So Ive been running a nzxt kraken for some bit for my cpu and just had fans for the gpu but im planning on upgrading to a full water cooled loop however ive no clue about compatabilitly so im not sure what specific parts i should be getting especially for my graphics card as its not a founders card so here are parts list
Graphics Card : Gigabyte RTX 2070 OC
CPU : I7 9700k
Mother board : Z390 Aorus Pro
Case : Phanteks Enthoo Pro M Tower
280mm Radiator can fit on top and i believe a 360mm Radiator can fit in the front if remove some case parts
Budget Isnt Huge. Recommend Parts that you get what you pay for, so decent parts that dont break the bank but arnt horrible x
It looks like EK does have a water block for your GPU.
https://www.ekwb.com/configurator/waterblock/3831109815878
For the 9700K and the RTX 2070 a 360mm Radiator would be good, though cost can balloon very fast.
Just as an example, something like this kit has just about everything including the mighty D5 pump though you will have to add the EK RTX 2070 block as above to the cost.
https://www.overclockers.co.uk/alphacool-eissturm-hurricane-copper-360mm-water-cooling-kit-complete-kit-wc-08h-ac.html
Of course you can buy everything seperatly like a pump reservoir combo, cpu block, radiator etc and this sight can give you some ideas as to what is available at all cost points..Not sure where you are from but I am sure there is a shop/site in your region that sells the same type of parts.
https://www.watercoolinguk.co.uk/
Again just as an example as there are so many ways you can go....
Cpu Block
https://www.watercoolinguk.co.uk/p/Bykski-CPU-XPR-B-PA-2018-Jet-Micro-Nickel-Plated-RBW-Symphony-Waterblock-INTEL_70652.html
Pump/Res
https://www.watercoolinguk.co.uk/p/WCUK-Spec-Barrow-D5-Vario-Pump--130mm-Reservoir-White_70276.html
Radiator
https://www.watercoolinguk.co.uk/p/Bykski-TN-Slimline-Triple-360mm-Copper-Radiator-1x360_69689.html
Choose whether you want hard tubing or soft and make sure you get the right size in/outer diameter for fittings.
Cpu Block
Pump/Res
Radiator
