Question Compatible Wifi module (AX 200NGW or AC 7265) for HP 8315 motherboard ?
Sep 15, 2022
*settled
Hello,
I just upgraded my RAM, damaging my Wifi module. :(:rolleyes:😢All specs below.
Would like to update the module on Wifi6/Bluetooth 5, but not sure, which wifi cards are compatible . :??: 😢
According to post found in HP forums there are two supported wifi cards in the service manual:
  1. Intel Dual Band Wireless-AC 7265 802.11 AC 2×2 WiFi + Bluetooth 4.2 Combo Adapter (nonvPro)
  2. Intel Dual Band Wireless-AC 3168 802.11AC 1×1 WiFi + Bluetooth 4.2 Combo Adapter (nonvPro)
or you could experiment with the Intel 9260 Dual Band AC card, non-Vpro (can only find them with vpro unfortunately).
Found an Intel 7265: https://amzn.eu/d/2R07H4w
But would rather install this AX 200NGW to have dual band / 5Ghz / even newer WLAN&Bluetooth. Is that possible? Would AX work as well, or does only AC work?
In advance, thank you so much for your help!!!
Leaving on Saturday for university and I'm panicking that my laptop won't work.
Laptop: HP Pavilion x360 Convertible 15-br009ng
Motherboard: HP 8315 33.22
CPU: Intel Core i5-7200U
RAM: 2x DDR4-2400 (SK Hynix HMA81GS6AFR8N-UH)
Current/Old Wifi Module: Intel 3168NGW (PCI Express Minicard)
