[SOLVED] Compatiblity of RAM to Motherboard need help
Oct 22, 2021
7
is 4gb JM DDR4 2666 U-DIMM 1Rx8 1.2V compatible with "Gigabyte GA-H270M-D3H" Motherboard ? Thank u in advance
2400MHz is maximum with a 7th gen processor and 6th gen maximum at 2133. Ram is compatible but won't run at 2666 and either defaults to 2400 (if ram module supports that speed) and cpu is 7th gen, or it down clocks to standard 2133 jedec spec regardless because ram doesn't have 2400 profile to negotiate motherboard with.
Reactions: Louiemark
Thank You
thank you
i still use that ram. then after i install windows 10 pro to it, after 1min, pc blue screen and say "whea uncorrectable error" then i pull out the plug, when i start it again, pc turn on and turn off,, even i remove the RAM, PC still turn on and turn off.. dont know why
