This weekend I cleaned the system and put a side panel case fan (bought it due to heating issues), since then I'm facing a issue. I have dual monitors, when I play BF3, sometimes it works fine for hours, and sometimes I get red screen. I checked the cables. Reset the graphic card. Just now I got red screen after playing 15-20 minutes. What's the issue? Graphic card is not faulty as I'm using it since December 2013. There are no broken pins also.
I noticed a broken pin but in this thread they told me it's by design.
So what else could be the reason?
I took a screenshot of the 2nd monitor when 1st monitor was complete red. These are the readings. Do you think graphic card is overheating? Or its RPM is higher than maximum?
Image (Hardware Monitor and AID64): http://i.imgur.com/5SRbQJd.jpg
