Hello,
I'll try to lay this out simple, as I tend to get carried away in forum posts...
Goal: Moving two WD raid0 hard drives from an old PC into a newer PC. Just trying to get some files from them---i.e. I do not want to clear/format/use them, just pull files from them.
Issues:
1. Raid is not set up on newer PC
2. BIOS freezes after about 3 seconds.
3. Main hard drive on the newer PC(not the ones im transferring) will not boot---that is, I AM UNABLE TO USE WINDOWS, and am doing everything via Ubuntu live.
4. Regarding the bios freeze, I have no PS2 keyboard to use if that is the issue (only usb wireless)
5. I cannot simply reconnect the HDDs to my old pc because its PSU is done.
Question: CAN IT BE DONE?
Appreciate any help, input. straight forward "No"s are welcome.
Background: My harddrive fails to boot windows, getting some 0x000000024 error, tried googling to fix it but no luck. Was going to build a new pc anyway so decided to just get my files from my hard drive using ubuntu (successful). I thought while i'm at it, why not connect the hard drives of my older PC (raid0 ones) to this one, use ubuntu and grab ALL my data together in one place. But didn't take into consideration setting up raid0...
Issues:
