Not the right time for a build, but here we go, my $1500 build
https://pcpartpicker.com/user/qzydo/saved/79nF8d
Here is my thought process, as I was clicking away in partpicker.
- Ryzen 7 3700x is octacore and would provide better performance over 3600. Apart from gaming, I run some simulations and use docker. Do you think I should go with 3600 and invest better on RTX 2070 Super ? Second question is directly related
- I have chosen the X570 Mobo, over the B450. Should I scale it back to a B450 and invest the money in 2070 Super ?. I would probably like to upgrade to a 4000 Series desktop Ryzen when they come out, as its said it have improved single threaded performance. Hence, I chose a better Mobo chipset, as a future proof. But what I really care for is top responsiveness in non-games and 1440P@144Hz at most of the games.
- I am not Intel averse and don't mind going with them as they still have the performance advantage. My question is how much of an advantage I get. Is it noticeable or is of just academic interest for benchmarks. Also, given Intel's superiority in single threaded applications, does the normal browsing and PC responsiveness better with them, or is Ryzen good enough ?
- I am aware that Intel is having issue with their 10nm chips, so does it make sense to go for a 9600K chip (I really would like the 9700k build, but it stresses my $1500 budget) and probably upgrade when the 10 series comes out ? I heard they are going to have some insane boost clocks
- Kindly see the other components, is there anywhere I can save some more money or am I bottlenecking the build with any of those parts.
- The monitor is unheard of (for me). I heard the priority (correct me if I am wrong) should be FPS > Monitor refresh rate > Monitor size (27" optimal ?) > Resolution. Does the monitor do justice to that, esp because its got only a 4ms response time (not 1ms) ?
- Finally 5700 XT vs 2060 Super. I really can't make my mind here. I heard the RTX support is limited in games (I am not a bigg gamer yet), so I choose 5700 XT which is better almost everywhere else. Do you feel, I should invest for a RTX support over higher FPS. Note, the target is 1440P@144Hz (the sweet spot now ?). Or should I cheap out in processor and Mobo and invest all those saving on a 2070 Super.
