Hello everyone,
I have a Victus 15L desktop that will freeze or randomly restart on it's own. I have had a blue screen a few times (component conflict error) but usually it will just freeze or randomly restart. There is no common theme to when it freezes or restarts. It can be a few minutes after booting up, during the booting up, or even after gaming for a few hours and then sitting idle for a bit. All temperatures seem stable and normal. Event viewer lists only Kernel power errors.
I have done the following to try to track down the problem:
- Run windows and UEFI based diagnostic tests which passed.
- Done a clean uninstall of graphics drivers using the AMD utility and installation of newest drivers.
- Put in a GPU from another computer
- Pulled out a stick of RAM to see if one stick was bad. The problem occurs with either stick of RAM. That plus the memory test completing with no error leads me to believe the RAM is fine. I suppose both sticks could be bad.
- Blown out ports with canned air and reseated the RAM and the GPU.
- Done a thorough Windows 11 reset.
- Turned off automatic reboot. The machine has frozen or rebooted anyway without a blue screen displaying an error. I suppose there might be a dump file with information somewhere but I'm not sure how to locate it.
At this point I suspect the motherboard is bad, though there might be an outside chance that the PSU is failing. It's also possible I missed something. I've noticed no domed or oozing capacitors on the Motherboard. There have also not been any burning smells or grinding sounds from the PSU.
If anyone has any other ideas I'm willing to hear them.
Can someone walk me through the proper procedure for diagnosing a failing motherboard , or failing HP proprietary PSU? I have a multi meter to help do this.
