Component questions for my 1700x build
SaintMorning
Hello, I would love to receive your oppinion and suggestions on the build I plan to purchase. First, this build should serve me the next 4-5 years, If neccessary I could add up 100-200 euros to my budget, if that would increase my build percentage wise such that it makes sense. So here is the my build:
CPU: AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor ($324.04 @ Amazon)
CPU Cooler: Noctua - NH-U12S 55.0 CFM CPU Cooler ($57.99 @ Amazon)
Motherboard: ASRock - X370 Taichi ATX AM4 Motherboard ($189.49 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3600 Memory ($204.99 @ Newegg)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive ($234.00 @ Amazon)
Video Card: Gainward - GeForce GTX 1080 8GB Phoenix GS Video Card
Case: Corsair - Crystal 570X RGB ATX Mid Tower Case ($165.98 @ Newegg)
Power Supply: SeaSonic - PRIME Titanium 850W 80+ Titanium Certified Fully-Modular ATX Power Supply ($196.99 @ SuperBiiz)
Total: $1373.48
Generated by PCPartPicker 2017-07-27 12:33 EDT-0400
1) I have a few questions which I have a hard time answering. First the motherboard: do you recommend to get the taichi over the ch6? Some say that vrms are better on the taichi, but I have heard that the fan system by taichi is bugged? Also, I'm using an usb audio interface, would either of the mobos interfere with the signal? My 8 year old mobo caused a little background noise.
2)I picked a 850W power supply, with the thought of purchasing a second 1080 when needed in the future. Would it be a problem to run my system with a 850W with only 1 1080?
3) Do you know whether to choose the m2 960 evo or the bpx480? I have heard that the bpx480 has better NAND and better endurance while the 960 has better specs? Regarding the cooler, I planned to move my pc like 5 times a year, so I thought it would be better not to get the big NH-D15. Would it still be sufficient for overclocking the 1700x on temperatures that guarantee long lifetime?
I planned to oc the 1700x to around 3.8-4ghz, and also I planned to flash the GLH bios on the phoenix, since the normal phoenix limits the TDP, and then also oc my graphicscard. I planned to oc, to get the most performance while also having the best lifetime that I need.. Again, I'm looking forward to ur answer.
4) I'm also very unsure about which case to use, I mainly wanted to pick the one that offers the best airflow while being the most silent.. I planned to maybe change my case if the tempered glass cases of computex 2017 appear to have good quality, airflow and temperature.if neccessary and possible to one of the upcoming tempered glass cases of computex 2017, if they are good quality and offer good airflow. That's why I went for the RGB version of the trident z, and I also planned to get the riing plus rrgb fans by thermaltake. Should I rather just get a case with one window and leave out the RGB stuff.. I researched about everything for several days, but right now I'm stuck.. please help me. I would be very very happy for your answer, suggestions, information.. whatsoever. I used a lot time researching but now I need help by someone with more knowledge than mine
Edit: Oh, I forgot to mention that... I have the asus P279Q as monitor. I would say I game 75% but I also code games and servers for games. That's why I thought the 1700x would be a good choice. I chose the ram, because I wanted to oc the ram to 3200 mhz. I picked the 3600 cl16, because they are the same price as the 3200 cl14 by gskill and these, because they are likely to be bdies.
The taichi is considered one of the best x370 boards but I don't know a lot about it, I think science studio did a review on YouTube.
Also just get the ryzen 1700 (non X) because it overclocks to the same performance as the 1800x.
The CPU cooler is high quality and will get you decent temps with an overclock.
Only one gtx 1080 will be fine for an 850w psu because it will only draw as much power from the wall as your system needs.
I know next to nothing about the SSDs sorry.
A case I like is the fractal design define s, it has good airflow it's pretty quiet and I think it looks nice.
As for overclocking ryzen CPUs AMD recommends not going above 1.35 volts.
