Components Compatibility help
It won't work with that build, new Intel processore require DDR4 RAM and there are no motherboards with DDR3 RAM support anymore for it. You can get something used, or get AMD FX/AMD Athlon x4, this both has motherboards with DDR3 memory support. But for FX 500W PSU is not enough, you need at least 600W PSU.
But instead of G4560 will intel i5 and this motherboard Gigabyte B85-HD3 work?
