J jshepnz Distinguished Sep 7, 2011 28 0 18,530 May 26, 2016 #1 Need to clarify if the Cooler Master Silenco 352 case can accommodate my CPU Cooler viz: Cooler Master Hyper 212X and my GPU GV-R577UD-1GD
Solution Dark Lord of Tech May 26, 2016 No the 212X won't fit , case only supports up to 155mm , 212X is around 158 or 159mm. Card will fit case supports. VGA card length: 355mm / 14.0 inch
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 May 26, 2016 Solution #2 No the 212X won't fit , case only supports up to 155mm , 212X is around 158 or 159mm. Card will fit case supports. VGA card length: 355mm / 14.0 inch Upvote 0 Downvote Solution
J jshepnz Distinguished Sep 7, 2011 28 0 18,530 May 26, 2016 #3 Am I better to change the case or the Cooler Upvote 0 Downvote
J jshepnz Distinguished Sep 7, 2011 28 0 18,530 May 26, 2016 #4 am I better to change my case or cooler Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 May 26, 2016 #5 That's up to you , cases are a personal touch. Upvote 0 Downvote
