Components Store Corrupted, Tried all Solutions With No Luck (Please Help)
Feb 5, 2019
Hello, I have been trying to fix my component store for some time now, but nothing works. When trying to install the .net framework 3.5, it gave me the error code 0x80073712.
I have tried DISM repairhealth, which gave me the error code 0x800f081f, then sfc detects nothing wrong, analyzing the component structure says nothing is wrong, and repairing it does nothing either. I have tried the DISM repairhealth command with both a mounted ISO and through the internet, and it keeps giving me 0x800f081f, or says source cannot be found in the case of the ISO. Even trying to do a repair installation gives me the same error. It's driving me insane, and I can't find a fix anywhere.
did you mount the iso? was the below steps what you did for the source command?
Download a copy of the win 10 iso from Here - create ISO by telling it you want to make DVD - and then mount that ISO in file explorer (see Here) and then copy paste the below command into command prompt (admin)
DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:X:\Sources\Install.wim:1 /LimitAccess
Where "X" is the drive letter where the ISO is located. Simply change the "X" to the correct drive letter
its odd you get the 0x800f081f error from running dism since its a .net error - https://support.microsoft.com/en-au/help/2734782/net-framework-3-5-installation-error-0x800f0906-0x800f081f-0x800f0907
Have you tried a repair install? https://www.tenforums.com/tutorials/16397-repair-install-windows-10-place-upgrade.html
I'm so sorry for the late response, I've been incredibly busy.
Yes, I have tried everything you've said. DISM can't find the source file when doing that, and a repair installation gives me the same error as DISM. I even tried to check the CBS log, and it reports corrupted files that don't even exist in regedit. I'm at my wits end.
