Componets help!
bobbybobcomputers
9
Just wondering if this set up will work together? And what you think about it! Thanks
A detailed response would be nice!
Antec Eleven Hundred Gamer Case
Silverstone Air Penetrator 120mm fan
Intel Core i7-3770k Processor 3.50 GHz w/8MB cache
Zalman CNPS9900 MAX CPU Cooler w/Blue LED
Asus Maximus V Formula with AC3 w/DDR3 7.1 audio, gigabit lan, CrossFireX/ SLI
Cosair ValueSelect 16GB DDR3 1333MHz CL9 Dual Channel Kit (2x8GB)
Cosair Force Series GS SATA lll Solid State Drive 240 GB
WD 2TB Caviar black 7200rpm SATA lll w/64MB cache
Asus 8x DVDRW slim external black
Asus HD7870 DirectCU ll V2 Radeon HD 7870 GHz Edition 2 GB PCI-E w/dual DVI, HDMI, displayport
Cosair professional series Gold AX1200 modular power supply
Cut back on your ram and powersupply. If you're gaming 8 gb is fine and for a single graphics card 1200 watts is way too much. Get 650 to be safe.
Upgrade your graphics card to a 7970 or 7950. Again, if you want to play games then and i7 is supposed to be too much, get an i5 3570. Get the K edition of it if you want to do overclocking.
Read the reviews of everything before you buy. I skipped the reviews of my powersupply, a corsair hx650 and got stuck with a psu that is defective in design. Makes whistling noises. The replacement had the same problem and now I'm waiting for the 2nd RMA.
I'm using this setup mainly for making music on FL STUDIO. So will all these parts work together tho? I'm just worried they wont fit in the motherboard or case. Also could i install a soundcard later on when i have more money? And would that be easy to install a SOUND card later on? So 650 watts is enough for this system? I'm gonna upgrade my graphics card to 7950 prob so the setup isnt bottledneck!
I'm gonna buy windows 7 and a monitor and keyboard. i already have a mouse. Would this setup be compatible tho? Like will everything fit into the ANTEC eleven hundred case and plug into the motherboard along with the extra 120mm fan i want to put?
heres something closer to what ud like for designing and maximum power.
PCPartPicker part list: http://pcpartpicker.com/p/yIOv
Price breakdown by merchant: http://pcpartpicker.com/p/yIOv/by_merchant/
Benchmarks: http://pcpartpicker.com/p/yIOv/benchmarks/
CPU: Intel Core i7-3930K 3.2GHz 6-Core Processor ($499.99 @ Microcenter)
CPU Cooler: Corsair H80 92.0 CFM Liquid CPU Cooler ($79.99 @ Newegg)
Motherboard: MSI X79A-GD45 (8D) ATX LGA2011 Motherboard ($241.25 @ Amazon)
Memory: Mushkin Blackline 32GB (4 x 8GB) DDR3-1600 Memory ($165.59 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ NCIX US)
Storage: OCZ Vertex 3 256GB 2.5" Solid State Disk ($166.99 @ Amazon)
Video Card: MSI GeForce GTX 660 2GB Video Card ($204.48 @ SuperBiiz)
Sound Card: Asus Xonar Essence STX 24-bit 192 KHz Sound Card ($185.99 @ Amazon)
Case: XClio Touch 767 ATX Full Tower Case ($89.99 @ Newegg)
Power Supply: XFX ProSeries 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($122.75 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ Outlet PC)
Monitor: LG E2742V-BN 27.0" Monitor ($229.99 @ NCIX US)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit) ($135.98 @ Outlet PC)
Mouse: Cooler Master CM Storm Sentinel Advance II Wired Laser Mouse ($44.24 @ NCIX US)
Total: $2277.20
(Generated by PCPartPicker 2013-01-21 00:18 EST-0500)
Base Total: $2368.21
Combo Discounts: -$20.00
Mail-in Rebates: -$30.00
Shipping: $8.99
Total: $2327.20
