Computer Based Drum module? Is it possible?
G
Guest
Guest
Archived from groups: rec.audio.pro,rec.music.makers.percussion (More info?)
Forgive for asking a question some may think is "behind the times". I just
know that this scenario has to be possible with today's computer based
technology, but I am unaware of any programs that will do this.
I want a computer based drum module that will act like the Roland TD-20
(which I saw at Summer NAMM and fell in love with). Some software that
reproduces snare buzz when a tom is struck and does not sound mechanical on
a snare roll.
So here's what I want: I plug my mesh pads into an Alesis DM5, assign each
pad a midi note, run the midi out on the DM5 to my computer sound card midi
in, trigger sounds with the realistic and adjustable parameters mentioned
above. Also...I want to control velocity curves and such of each pad from
the computer software thru the midi cord and not on the DM5...basically the
dm5 is just used as a midi converter.
What software will do this? Thanks so much!
Doug in Tennessee
Yes. You use some sample-playing software like Kontakt and then load it with
whatever sample package you choose like "Drums from Hell" or BFD. The cost
of the software is equivalent to the TD-20, so it's a wash....except that
you can have a better setup with a PC than the TD-20. Instead of modeling
the sounds, think 12-16 velocity layered snare samples (in other words, when
you hit softly, a studio sample of a snare being hit softly is played. a
little louder, and a sample of a snare being hit a little louder is faded in
and the first sample is faded out a bit....etc.)
You also need a mogambo PC to do this with 2.5 GHZ or higher. 1.5 Gigs of
RAM or more.
Lots of info on www.vdrums.com
....Joey
"rothman_24" <drisp@hotmail.com> wrote in message
news:guE0d.140927$%n4.338@bignews6.bellsouth.net...
on
> a snare roll.
each
midi
the
> Doug in Tennessee
Thank You, Thank you Joey!!!
"Joey" <joeyfurr@yahoo.com> wrote in message
news:jPadnYM_dILKs97cRVn-iA@comcast.com...
with
when
in
> RAM or more.
> ...Joey
just
> on
> > a snare roll.
> each
> midi
mentioned
from
> the
> > Doug in Tennessee
There are programs that act as sound modules available. You can store an
assload of samples on them and get these to trigger via the midi in.
GigaSampler is the one I've heard most about. But I'll bet there aren't
drum functions specifically (like your mention of snare buzz when you hit
toms). But many studio producer types use this product with drum sample
packs with success - probably not so good for real-time like a dedicated
brain. I suspect the delay would drive you nuts even though it'sonly a
couple milliseconds.
my .02
dik
If your soundcard is a soundblaster, just try to find yourself a good
drumset soundfont, and you're set.
Some soundfont FAQ: http://www.dublab.dk/contents/sf_faq.htm
Kevin Buffardi
"Rockstars -- is there
anything they don't know?"
-Homer Simpson
If I'm reading you right, Battery from Native Instruments will do it, in
either stand-alone or VSTi form.
Neil Henderson
Saqqara Records
http://www.saqqararecords.com
"Animix" <animix_spamless_@animas.net> wrote in message
news:ci0fa302u62@enews1.newsguy.com...
> I'm fried from listening to (((((%^*$^% drums all (%^&&^ day!
Deej, i just hope you used the LDC's for the overheads & the SDC's for the
room mics.
Neil Henderson
Saqqara Records
"Kevin Buffardi" <kbuff1xw@mwc.edu> wrote in message
news:2qgqdgFv6s98U1@uni-berlin.de...
You're right. There's some darn good soundfonts out there if you look
around.
news:ci0fa302u62@enews1.newsguy.com:
> I'll finish mapping a TrapKAT to BFD nest week.......at least I think
> I will. I know it's possible with a Ddrum kit and a DrumKAT. The
> TrapKAT is a little different, but is probably not too different from
> the DrumKAT.
Whats different except for the fact that it has more pads?
I've found Hammersound's website (hammersound.net) and their newsgroup
(silco.hammersound.soundfonts on news.silco.com) are very helpful. Amongst
a lot of mediocre soundfonts, you'll find some great ones. I'm building up
a pretty decent collection of various pianos.
I've found drumsets that work, although none of them have blown me away yet.
Kinda wish I had taken the time to make really good samples of each part of
my drums.
Kevin Buffardi
-Homer Simpson
Go to virtualdrum.co.uk and sign up to get you free Virtual Drum module software. It will be released in 2011 and has velocity triggered samples offering sounds that electric drum kits cant deliver alone. all samples are recorded by legendary producer Ross Orton (see wikipedia).
Thanks
Lee Armitage (Virtual Drum)
