Question Computer BSOD when using Silicon Power P34A60
Aug 7, 2022
I recently built a computer with the following specs:
  • AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor
  • MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard
  • Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory
  • Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive
  • Silicon Power P34A60 512 GB M.2-2280 NVME Solid State Drive
  • Gigabyte GeForce RTX 3060 12 GB EAGLE OC Rev 2.0 Video Card
  • EVGA SuperNOVA GA 650 W 80+ Gold Certified Fully Modular ATX Power Supply
The underlined Silicon Power P34A60 is the issue. When I built the computer, it wouldn't get past the "getting devices ready" section so I assumed the SP drive was dead, ordered a replacement and temporarily swapped in a smaller SATA SSD. The new drive arrived today so I installed it, cloned the temporary SATA SSD to it, and attempted to boot with it. Now whenever I try to boot off of the new SP drive, the computer BSODs. The temporary drive that was cloned still boots fine, but the new drive will not work at all. I checked compatibly with both of my motherboard's slots and tried the drive in both but no dice either time. What is wrong here? Do I have an incompatible part? I'm at my wit's end trying to figure out what on earth is wrong with my drive.
Aug 7, 2022
Can you check and see what your BIOS version for the motherboard is at this moment of time?
Thanks for your quick reply (sorry mine's a little late)! The current BIOS Version is E7C95AMS.290 and the BIOS Build Date is 12/23/2021
