Hello, I have been a gamer for a while. Recently I began looking into PC gaming (I've been using a laptop). When it comes to tech stuff I'm not fresh out of the box, but I don't have a lot of experience.
I've looked up some recommendations and tutorial type stuff (on here and newegg). I put together a list of parts I think I'd like to use to build a PC (http://pcpartpicker.com/p/PBhdgs). Feel free to just post a link to another discussion that answers one of the questions.
I realize it's a lot of information and a lot to read. I would very much appreciate any and all recommendations, tips, suggestions, etc. Thank you.
Purpose:
I'm going to be gaming (as mentioned above). As far as specific games, I don't know. I play some mmorpg (LOL), some solo games (Borderlands, Dishonored, Deus Ex). I do surf the web a lot. I do not do a heavy amount of photoshop/gimp or anything like that (including video editing). And I'm only going with a single monitor for now.
I'm not super rich, I'm not trying to get the best of the best or latest and greatest, but Christmas is coming up and I've saved some money. I was hoping to not go beyond $1,000. Yes I do realize the current build is about 20% beyond that. While I know I could cut back on some of the parts since I won't be going all out for gaming and usage, I would like a system that can handle what I throw at it, even some years from now when things get heavier.
Also, I don't know enough about overclocking to feel comfortable trying it, especially on my first go round with building a PC. The capability is there, though, in case I decide to try it later. I do know I'd need an aftermarket cooling fan to do so.
Parts List:
CPU: Intel Core i5-4690K 3.5 GHz Quad-Core Processor.
Cooler: Stock, whatever comes with the CPU.
Motherboard: ASUS Z97-AR ATX LGA1150
GPU: ASUS Tadeon R9 290 4GB DirectCU II
RAM: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Crucial MX100 128GB 2.5 SSD (this I'll use to boot and run the OS)
Western Digital (WD) Green 2TB 3.5" 5400RPM IHD (this will be for everything else)
PSU: Corsair RM 750W 800+ Gold Certified Fully-Modular ATX Power Supply. Yes I know this is very high end, and I could probably get by with less. [see question 9]
Case: Enermax ECA3280 A-BL ATX Mid Tower
Optical Drive: ASUS DRW-24B1ST
OS: Microsoft Windows 8.1 (OEM) (64-bit)
[the Optical Drive and the OS are not huge concerns at all, they are both fairly basic and I simply included them for the sake completeness.]
Questions:
1.) Are all the parts compatible? I do know the website (pcpartpicker.com) does have the compatibility notes, so if anything is wrong, it'd show up there. I just want to make sure there isn't something that it might not catch.
2.) Is the note in the link a big deal? It's 1mm, so my guess would be "no". Again, I just want to be sure.
3.) The mother board and case both have ATX forms. I don't see any standoffs in the pictures I could find. Are they commonly included vs not? I assume it's not a big deal to have to get them. Though it is a big deal to have them, proper grounding and all that.
4.) I'm using the standard, in package, (not sure of the correct term) cooling fan. As opposed to an after-market one [see "purpose" for the reason]. Having only gamed on my laptop, I know it can get pretty hot. Will this be an issue? Should I get an after-market cooling fan?
5.) If so, what's recommended? I saw a tower cooler (I think it's called). As an engineer, that looks like it would incur a lot of torque on the cpu to hang off the side like that. Not a good thing for a cpu to be under torque.
6.) One of the tutorials I saw/read mentioned something about a spec. of SSD allowing it to be forward compatible. I don't know how to tell this about the selected SSD (or any for that matter).
7.) A plug, I think it was mobo or moba. I don't remember much about it, I think it might have had to do with the fan . Does anyone know what this is and if I should worry about it? I tried googling it, but didn't see anything I recognized. "mobo" comes up as "motherboard" and "moba" comes up as the type of gaming.
8.) Fan noise. How do I tell if this will be an issue? I guess this kinda ties back into questions 4 and 5.
9.) Is there a general easy way to find the wattage needed for the PSU? I looked under the specs for each part on pcpartpicker and there were only two parts that listed a wattage needed totaling about 325w. I would assume more is better than less.
10.) SATA and PCIe. Not really sure what these are other than a type of connection for data. Yes I can go read the literal definition, but I don't understand what it is, though that's not my concern mainly. It was recommended that I have some form of each of these. Though there's like 3 different kinds of each. So I'm not really sure what I need/want and if I have what I need/want.
11.) WD Green vs Black. My understanding for this is: green is simply slower than black, and somehow that affects storage (aside from writing speed). Since I'll be doing gaming, is this going to be an issue?
12.) Case size. The motherboard should fit (they're both ATX forms). The case is about 19" x 19.5" x 9.5". Is this going to be enough room for my case or will I need to go for a full tower?
13.) General upgrade/downgrade part(s). Is there anything you guys would suggest switching out for something else? Please give a reason, Thank you.
Thank you again
Purpose:
Parts List:
Questions:
Thank you again
