CPU: https://www.newegg.com/Product/Product.aspx?Item=N82E16819113437&cm_re=ryzen-_-19-113-437-_-Product (AMD RYZEN 5 1400 4-Core 3.2 GHz (3.4 GHz Turbo) Socket AM4 65W YD1400BBAEBOX Desktop Processor) $170
GPU: https://www.newegg.com/Product/Product.aspx?Item=N82E16814487291 (EVGA GeForce GTX 1050 Ti SC GAMING, 04G-P4-6253-KR, 4GB GDDR5, DX12 OSD Support (PXOC)) $140
Mobo: https://www.newegg.com/Product/Product.aspx?Item=N82E16813132965&cm_re=motherboard_AM4-_-13-132-965-_-Product (WE ARE CURRENTLY NOT SURE IF THIS IS A COMPATIBLE MOTHERBOARD! WE HAVE AGREED THAT THIS SHOULD BE COMPATIBLE WITH OUR CPU, BUT WE DO NOT KNOW IT’S CHIPSET: ASUS PRIME B350-PLUS AM4 AMD B350 SATA 6Gb/s USB 3.1 USB 3.0 HDMI ATX Motherboards - AMD) $100
PSU: https://www.newegg.com/Product/Product.aspx?Item=N82E16817139112&cm_re=power_supply_80_plus_bronze-_-17-139-112-_-Product (MAKE SURE TO REVIEW ALL COMPONENTS: Corsair Certified CX-M Series CX750M 750W 80 Plus Bronze Active PFC Modular Power Supply) $60
RAM: https://www.newegg.com/Product/Product.aspx?item=N82E16820104532 (ON THE LINE FOR REVIEW: HyperX Fury 8GB (2 x 4GB) DDR4 2133MHz DRAM (Desktop Memory) CL14 1.2V DIMM (288-pin) HX421C14FBK2/8 (Intel XMP, AMD Ryzen) $68.79
SSD: https://www.newegg.com/Product/Product.aspx?Item=N82E16820173150 (SanDisk SSD PLUS 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) SDSSDA-120G-G26) $60
HDD: https://www.newegg.com/Product/Product.aspx?Item=N82E16822235089&ignorebbr=1 (WD Black 1TB Mobile Hard Disk Drive - 7200 RPM SATA 6Gb/s 32MB Cache 2.5 Inch - WD10JPLX) $70
Case: https://www.newegg.com/Product/Product.aspx?Item=N82E16811139078&ignorebbr=1 (Corsair Carbide Series CC-9011093-WW White/Blue ATX Mid Tower SPEC-ALPHA Mid-Tower Gaming Case ATX Power Supply) $80
All the information above is a system I want to create. However, my question is, are these parts compatible with each other? Also, even though the case says that it can support 2 3.0 USB Ports, can I still add more? Or is that the IO shield? Finally, if you think there is something wrong that you wouldn't include in your build, please explain! God bless anyone who can help, this is going to be my first build, and I would really, truly appreciate any help! Thanks, A LOT!
