Computer build... need some help
BMuelz
6
Here is what i found so far...
input would be nice and some help. I havent built a computer in over 4 years so i am out of the loop with all the new stuff out right now:
Hopefully everything is compatible. Suggestions would be great!! Would like to stay in the price range of under $350 because i need to buy other accesories for the computer still
Case:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7983375&sku=A406-8005
CPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1239961&sku=A79-6100
MB: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3858653&sku=G452-7800
RAM (x2): http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2225792&sku=A208-5014
HD (also connecting a TB external):
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7281716&sku=TSD-500AAKX
yeahhh... that will be better..plus if you go with ASUS M5A97 LE R2.0..that is alot better mobo trust me it supports 1600MHZ ram... so you wont be left out incase you want to change your mind and thinks to install a faster ram..
The ASUS M5A97 LE R2.0 is an ATX board which wont fit in my case i dont think because i need a MICRO ATX since i am using a small case... i may be wrong though?
