Computer build problem
Josef_5
Commendable
Jan 19, 2017
I have recently completed a build with the following completed a build with the following components:
- Intel Core i5-7500 3.4GHz Quad-Core Processor
- Asus PRIME B250M-A Micro ATX LGA1151 Motherboard
- Crucial 8GB (1 x 8GB) DDR4-2133 Memory
- Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal
- Zotac GeForce GTX 1060 3GB 3GB Mini Video Card
- Cooler Master N300 ATX Mid Tower Case
-EVGA 500W 80+ Bronze Certified ATX Power Supply.
However the PC wont turn on, i have checked the 'My computer wont turn on' forum and still nothing. the motherboard lights up but no fans spin or anything.
Here is a picture of the completed build:
http://imgur.com/gallery/qvQQI
Thanks!
I have made sure that the connectors are properly seated, I have also tried with the RAM sticks in each slot, any other ideas? thanks for the speedy response
I am getting exactly the same issue. Did you get your problem sorted? If so how did you figure it out.
Cheers ste425
