Computer Building Help
FrescaSodaGames
15
I'm gonna build the computer everyone... after some consideration I am going to build a computer
BUT
Will the parts fit together
I will tell you the parts if you need them
I will list a build but take the time to read into PC systems, Intel and AMD based ones and how the motherboard is compatible with the CPU etc. You could use some knowledge.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($199.99 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard ($153.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory ($99.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.88 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5"...
GRAPHICS: Gigabyte Geforce GTX 950 Xtreme Gaming
MOTHERBOARD: Gigabyte Z170X-UD5 TH Intel Thunderbolt 3 or Asus ROG Maximus VIII Formula
CASE: Fractal Design Define S with Window Side Panel Slider
COOLING: be quiet! Dark Rock Pro 3
SOFTWARE: Windows 10
MEMORY: Ripjaw G.SKILL F4-3000C14Q-32GVK
POWER SUPPLY: EVGA SuperNOVA 550 GS 80+ GOLD
MONITOR:Acer S220HQL Abd 21.5-Inch Widescreen LCD
If you need anything else let me know
Also if there ar cheaper alternatives that give close to the same performance
Thanks
-FSG
Given this level of info, I guarantee there will be one or more parts from your list that need to be changed.
Also if there are cheaper alternatives that give close to the same performance
Thanks
-FSG
Thanks
-FSG
Well yeah we see a components list, I mean sure, but is the purpose of it for gaming? And can you list a full build including processor and HDD/SSD? For which price do you want to build at most?
A lot more information is in place so we can get atleast an idea of which build is going to be ideal for your use. Also do you care about color pattern? Like black/red, white/black etc.
I would prefer if possible blue and black
at the most maybe 1500$- 2000$
gaming
PROCESSOR:AMD FX-4350 Vishera Quad-Core 4.2 GHz Socket AM3+ 125W FD4350FRHKBOX Desktop Processor
and ssd
Well...that is an AMD processor, which will not work with your chosen Intel platform motherboards.
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: XFX Radeon R9 390X 8GB Double Dissipation Video Card ($408.98 @ Newegg)
Case: NZXT H440 (Matte Black) ATX Mid Tower Case ($93.99 @ NCIX US)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($113.98 @ Newegg)
Total: $1236.18
Generated by PCPartPicker 2016-01-08 21:12 EST-0500
