Computer case help
zxvipers
51
I'm looking at buying a new case, but a problem I have with my current one is too small to hold the hyper 212x. I'd like a case in the range of £50-£80. The case I have currently is the Comrade Bitfenix, and one I was looking at was the NZXT S340 Mid Tower PC Case. My motherboard is the F2A88XM-DS2 if you need it for sizing. Also if this case isn't big enough to fit the hyper 212x, recommendations would be appreciated thanks.
You have a nice case. Why not just put in a cooler that fits?
Hyper212 is 159mm tall; it might be close.
The cryorig H7 is a better cooler that is easier to install at about the same price.
It is 145 mm tall, certainly cheaper than a new case.
zxvipers
51
No because I was having temperature issues so I bought that hyper 212x, and I'm not a huge fan of the case. So I want a new case not a new cooler...
Similar threads
