Good case, I used to own one! All you have to do is remove the four screws. There should be a fan, a filter, and an medal support plate for the filter. After removing those you can just screw in a new fan. I'm not sure about the filter and support as I think they are designed with nzxt fans so different brands might not have the same indentations.
