W wiryjacbo Reputable May 8, 2014 1 0 4,510 May 8, 2014 #1 I am connected direcly to my modem via wireless and ethernet but I have limited access . All other devices on network connect
Solution B B boosted1g May 9, 2014 You may have a Static IP set on your device On problem device, open a command prompt and type ipconfig and paste the results on a device that is working, do the same thing and paste the results.
B boosted1g Titan Jun 12, 2013 14,851 12 81,765 May 9, 2014 Solution #2 You may have a Static IP set on your device On problem device, open a command prompt and type ipconfig and paste the results on a device that is working, do the same thing and paste the results. Upvote 0 Downvote Solution
