Question Computer CPU fan starts than stops, while GPU fans are spinning fully.
May 12, 2020
I had started building a PC for my friend, the PC had successfully booted once. But read CPU fan error and the SSD was not detected.
So I put the CPU fan in the right slot (I had it plugged in a case fan slot instead of a cpu fan slot) and also reseated the ssd.
Now my computer will not show any signs of output (the hdmi plugged into GPU) and the CPU fan is lit up and starts spinning than stops. The GPU fan seems to be spinning at full throttle indefinitely.
What should i do?
