Hey folks! I built my computer about 2 years ago, and have no problems since then. In the last two weeks, I would come home from work to find my computer had restarted. Strange, but maybe it was a windows update. I continued using it normally, until it started crashing while I was doing normal idle business like using Chrome or browsing my steam library. At this point I've tried everything I can think of and can get on short notice from Best Buy.
What the problem looks like
Event Viewer After Crash
- While idle (meaning when running nothing, or just a browser, or just Event Viewer/File Explorer), my monitor will go dark, and all of the fans in my case will spin up. Then, I will be shown the brief booting image, and will be taken back to the login screen. Event Viewer shows a critical failure, which is listed below. When I have ran stress tests to see if this is due to the computer overheating, the computer is totally fine, but as soon as the tests are done, there is an error again. If I run a video game in the background (I've done it with Minecraft and Risk of Rain 2), the computer will not crash while the game is open.
- I was able to replicate the problem only twice by editing the sleep/power settings in Windows Settings. The pc had been running on High Performance Mode, but when I switched it to Balanced Power Mode, it instantly restarted. I was able to replicate this twice, but more attempts showed that might have just been bad timing.
- Processor: AMD Ryzen 7 3700X
- Motherboard: MPG X570 Gaming Plus (MS-7C37)
- RAM: 32 GB of G-Skill RAM (2 Sticks)
- Power Supply: Corsair 850x, Fully Modular, Gold Rated
- Graphics Card: NVIDIA GeForce RTX 2080
- CPU Cooler: Corsair H100x (liquid cooled)
- (Source of the crash) Critical Failure, Kernel-Power - 41
- (Could be related?) Error, WHEA Logger - 18
- CMD -> SFC /SCANNOW (Which ran and was successful)
- CMD -> DISM.EXE /ONLINE /CLEANUPIMAGE /RESTOREHEALTH (completed successfully)
- Updated BIOS for my Motherboard to the most recent version
- Turned off "Link State Power Management"
- Uninstalled/Reinstalled Chrome (assuming it was a Chrome issue, but this did not work)
- Removed Device with a broken driver (one of my peripherals was giving an error in Device Manager, so I physically removed the device)
- Ran OCCT, which is a stress testing software, to see how the computer would handle a heavy load. After two tests that lasted 30 minutes and 1 hour respectively, the computer passed with flying colors. Then crashed after I closed OCCT and was only looking at event viewer.
- Ran Malwarebytes Premium - Antivirus
- Ran Webroot Premium - Antivirus
- Under recommendation from a store near me, I purchased a new SSD, removed my old drives, and installed this new one. I also downloaded a fresh install of Windows to a USB. The computer crashed multiple times during install.
- Reset CMOS
- Reseated RAM (tried running with one stick, and then the other - both resulted in a crash after some time)
- Reseated/cleaned Graphics Card
- Reseated/cleaned Power Supply
- Computer is Browning Out, and the Power Supply is faulty for ??? reason. I have not taken out my Power Supply completely because I am still in diagnosis mode. The only issue is that it only crashes (from what I've seen) under a low intensity load.
- Motherboard has some sort of hardware failure that is causing this resetting problem.
- I DO NOT think it's an overheating problem, especially due to the stress tests being successful
