Computer died - power supply or motherboard?
wildestseas
11
My computer has been running very stable since a cpu upgrade four months ago. Tonight I fired up Bioshock 2 and a few minutes in, the computer just shut off like someone flipped a light switch - no warning.
The 400w power supply was too hot to touch and I got a small static shock when I touched the case. Doesn't seem good. I let it cool down and then tried to boot - nothing - it behaves like the power is completely off. I disconnected the motherboard and components and then tested the 20+ pin ATX power plug using a voltage probe - it has power - at least enough to run a small light bulb.
What doesn't have power is the 4 pin 12v power plug that connects to the MB near the cpu.
Is this normal that I wouldn't be able to see a current in the 4 pin power plug using a voltage probe grounded to the case?
Is there any sort of test I could use to rule-out the power supply besides try it with a new MB?
Components:
Rosewill 400 W (max) power supply
MSI K9A2 CF V2 (125 W max CPU support)
AMD Phenom II 955 X4 3.2 GHz processor (125 W)
Asus EN9600GSO Nvidia 9600 GSO GPU w 384mb DDR3
4 GB OCZ DDR2 PC2-6400 RAM
Western Digital Caviar Black 640GB
Western Digital Caviar Blue 500GB
jsc
Champion
Sigh.
The paperclip trick can tell you if a power supply is bad. No activity generally means a dead PSU.
But it cannot tell you if the PSU is good. It doesn't check the 3.3 or 5 volt outputs. It doesn't check for the presence of the PowerOK signal (grey wire, pin 8). And it doesn't check the PSU under any load.
The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboarding
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
