Question Computer does not power on as it should
Dec 5, 2019
At times my pc doesn't boot up when i click the power button, no fans spinning, psu idle, cpu idle nothing, but then after 10 or so seconds it turns on. sometimes when i try to start it, it just wont turn on unless i hold the power button(tried this only once so i cant tell if it works) or turn psu off and on.
I have changed my old motherboard thinking it might be it, problem was solved for 3 days but it came back, here are my specs -
gtx 1660 ti gigabyte oc,
i7 4770k,
h87-hd3 mobo,
8gb ram 1600mhz,
cooler master mwe 650w gold.
After computer turns on after a delay and i start it over and over for 20+ times it always powers on instantly, so what is the issue here? psu is under warranty but i think they will just send it back if i ask for refund.
Latest posts
