Question Computer Does not power on
Jan 29, 2020
Hey Everyone. Just purchased new parts for my new computer system. Build is:
MOBO: GIGABYTE X570 AORUS ELITE WIFI
GPU: GIGABYTE Radeon RX 5700 XT
PSU: CORSAIR RM Series RM750
CPU: AMD RYZEN 5 3600X
MEM: corsair dominator platinum
So after getting it all set up, I powered it on and all the fans began running, lights on, etc. everything seems to run normally except that the monitor stayed black. I could not see anything on the screen and it was running like that for 5 minutes.
So I then powered the computer off thinking something was wrong. Once it was turned off, I double checked all my connections and everything seems correct. I went to turn it on again and now nothing powers on. I do get lights from my memory sticks, but that is it.
Any thoughts?
rickypicky5
Proper
Sep 9, 2019
219
22
115
8
Did you double check your connection from your GPU to your monitor? Did you try to get into the BIOS? When you powered it off, did you turn the switch on the back of the PSU off and forget to turn it back on?
Jan 29, 2020
I just hooked up my new power supply to my old computer and it did not power up. so I think it might be the power supply. I will try my old power unit on the new computer and see what happens.
