To describe my situation is going to take a while to be honest. This issue started on the 7th and 17th of August and at first my computer would shut down and restart itself. After a couple of hours it would boot up normally and it continued to work normally until the 17th then it happened again but this time it just shut down and would not turn back on.
I have gone to NCIX for a diagnostic and they basically did nothing, told me all my components were fine and they left my PC on for 2 days and there were no shut downs at all. I bring my PC home and I try using a different outlet and surge protector and at the first try of starting my computer it turns on but shuts down afterwards and does not turn back on. After all of this I decided to replace my motherboard and processor in case there were bad ports or a shorting issue and yesterday when I reassembled my computer in a new case with the new parts, I also used a different power cord and a new surge protector but I got the same issue AGAIN. It would turn on then shut down and I would not be able to turn it on.
Fast forward to today and I tried starting my computer again and this time it boots up fine and I go through the whole process of installing Windows and activating it, then I shut down my computer manually and I try to turn it on but it just doesn't turn on again, the PSU makes a clicking noise then nothing.
My Specs are:
Intel Core i7 4790K Quad Core @ 4GHZ
ASUS Z97 Pro Gamer ATX LGA1150
EVGA GeForce GTX 970 Superclocked ACX 2.0 4GB GDDR5
Cooler Master V750 - Compact 750W 80 PLUS Gold Modular PSU
Kingston HyperX Fury 16GB Kit (2x8GB) 1866MHz DDR3
Crucial BX200 480GB SATA SSD
My Specs are:
