Hello, I am currently in the midst of building a computer for the first time and after finally getting it to boot up and install Windows, I decided to put in the wires for the Phanteks LED strip and fans that came with the P400S case I bought.
I connected a 12v wire with a SATA PSU wire and connected the LED strip with the case front panel on one side and a 4 pin wire with USB headers on the motherboard.
Then I connected the fan wires with the fan headers on the motherboard. After that, I turned the PC on again and a blue flash appeared for a second and the PC shutoff. I have no idea what exactly happened and I am unable to turn on the PC at all.
I also tried turning the PSU on and off and have noticed the white lights that are always lit
on the GPU near the PCIe ports are not lit.
Anyone have any idea what happened and how to fix this?
Also some PC specs if it helps:
EVGA Supernova G3 650W PSU
ASUS GTX 1070 8GB ROG Strix
Gigabyte Z87N WiFi
i5 4690k
Gigabyte Z87N WiFi
i5 4690k
