Computer doesn't boot after installing water cooling and changing cases
Harley_17
Hi everyone this Is my first post so excuse, yesterday I installed a water cooling system into my PC and for that I bought a new case, so all my components were disconnected and then added to the me case, after id finished I turned It on and I got the your computer was unable to start, is there a way to fix this? I really dont want to wipe my pc as I have loads of pictures on there, yes I made the error of no backing It up, any help would be greatly appreciated, thank you
Specs would help.
Specifically the cooler and the MB.
Is it possible you plugged the cooler into the MB in the wrong place?
I know on my board it has spots for a pump and an optional fan as well as THE CPU fan, all right next to each other and if I don't plug into the CPU fan port it won't boot even though I have a liquid cooler as well.
If you have a custom rig they would all need to be plugged in correctly. I know at least on my MB, it won't boot unless there is a fan connected to the CPU_Fan port.
sorry forgot to take this down it seems my sata cables were plugged into sata express instead of sata 3 ports which kept it from booting
