Hi, my pc have suddenly stopped working and I can't figure what it could be. When I click to turn it on, the cpu fan start spinning and the LAN LEDs also turn on but it doesn't POST. The speaker is working but doesn't do the single beep and there is no display. The display port is vga and is connected to the board
Specs:
The last thing I did: that PC had 5 GPUs connected through risers. For this I had to disable the 3.0 asmedia controller and hd audio controller on the bios. All was good. I wanted to add a 6th GPU and had to disable the LAN controller. Connected a usb to ethernet adapter, turn on windows to check if it works. It does, so I disabled the LAN port. I think it never POST'd after this
What I tried:
Any additional suggestions are welcome, thank you for your time
Specs:
- MB: asus AM1M-A
- CPU: AMD 5350
- PSU: 750w whisper modular
- SSD
What I tried:
- Turning everything off and on (including cables)
- Disconnecting every GPU and just leave the board + cpu + ssd (also tried without the ssd)
- Powering everything off and taking the CMOS battery for a few hours and shorting the CMOS reset pins
- Taking out the RAM (it beeps to signalizing it if I try to turn it on)
- Change RAM sticks
- Take CPU power and try to turn on (no beeps)
