Hello everyone!
My 3 MONTHS OLD custom-built pc doesn't turn on when I push the power button. This happened three times previously, after perfectly normal shut-downs. Usually I would push the power button like mad multiple times, and it would magically turn itself on. Well the miracle is not happening this time...
The motherboard showed no blinking light, nothing inside was running. When tested the PSU, it ran perfectly fine, and powered up a spare PC just fine! I did a power resetting (where one have to unplug the components and hold on to the power button for 20 secs), but no luck. I did check the wire, the power outlet, the PSU switch, everything!
I'm worrying whether the MOBO has gone crazy (though it showed no sign of performance failure, no BSOD, no random crash whatsoever), or it's just a problem with the mere power button.
Please let me know what you guys think! Anything would be helpful, I'm desperate 🙁
---- The build---
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($179.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Motherboard: ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard ($84.99 @ Newegg)
Memory: PNY 8GB (2 x 4GB) DDR3-1866 Memory ($57.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Video Card: Gigabyte GeForce GTX 770 2GB Video Card ($399.99 @ Amazon)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm Fan ($2.99 @ Newegg)
Power Supply: XFX 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.99 @ Newegg)
---- The build---
